car won't start. CEL went on, then car died
Old Jun 10, 2012 | 05:34 PM
street_racer_271's Avatar
Default car won't start. CEL went on, then car died
I found out a few weeks ago that my gas tank was contaminated. I replaced it. Leak tested everything, it ran flawlessly. Replaced the fuel pump as well. Drove it today, it seemed like it was choking out when i hit the gas, and ran very lean. So i was on my way home to clean out the fuel filtler, when my CEL comes on, and car dies. I have since cleaned out my fuel filter, replaced my injectors. Tested 4 PGM-FI relays, they all work in my other civic. Tested both of my ecu's as well, both started my car fine.
When I turn the key, the PGM-FI relay doesn't turn on at all. CEL stays on, jumper wire doesn't do anything. CEL just stays on solid. I've tried all 3 of my main relays, checked all the fuses, tried another ecu, and nothing happens.
Please help
1992 Honda Civic VX, 1994 B18C1 motor, P72 ECU
Old Jun 10, 2012 | 06:26 PM
Former User's Avatar
Default Re: car won't start. CEL went on, then car died
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Jun 10, 2012 | 06:50 PM
sorry, added my info
Old Jun 10, 2012 | 06:53 PM
Check fuses 31 and 24.
Old Jun 10, 2012 | 07:16 PM
Jdmbryan's Avatar
fuse under the hood, first one all the way up top on the left.
Old Jun 10, 2012 | 08:01 PM
Both are good. Even replaced the good ones with new ones, still same thing
Old Jun 10, 2012 | 08:05 PM
Do you know where the two fuses are located?
Test whether installed fuses 31 and 24 have battery voltage on both top test tabs.
Then clean and tighten the G101 ground on the thermostat housing.
Old Jun 10, 2012 | 08:53 PM
Yes I do. 31 is labeled ecu in the engine bay fuse box, and is 15 amps, the other has a 20 amp fuse and is labeled as ACG. Cleaned the ground. Still nothing. Also inspected fuel pump, everything is connected properly. Just the main relay isn't getting power
Old Jun 11, 2012 | 06:24 AM
wtfisvtec??'s Avatar
do you have differenent injectors with a resistor box?
Old Jun 11, 2012 | 07:53 AM
No resistor box. The car was driving just fine yesterday. Wire #5 on the PGMFI relay isn't getting any power. No wiring was touched or changed prior to the incident. I've changed all appropriate fuses already
GOT IT RUNNING!!! So no power to ignition wire on the relay, so i just ran a jumper wire from it directly to the ignition plug at the fuse box.
Thanks for your help guys
ttcheung97
Aug 24, 2020 06:31 AM
Zeratul
Engine Management and Tuning
Sep 28, 2016 03:31 PM
hotinteggy
Oct 22, 2007 04:44 PM
Lucky-13
Mar 21, 2007 01:54 PM
Morning Call
Jul 19, 2006 03:14 PM
