Solid CEL on a B16
Old Mar 20, 2007 | 03:33 PM
Lucky-13's Avatar
Default Solid CEL on a B16
Like the title says, I jumped the 2 pin, grounded A13 and its just a solid cel......anyone got some ideas?? Thanks in advance!!
Old Mar 20, 2007 | 03:59 PM
pdiggitydogg's Avatar
solid cel means bad ecu....that or youre not jumping it correctly/with something that conducts a current
Old Mar 20, 2007 | 04:06 PM
Lucky-13's Avatar
Default Re: (pdiggitydogg)
Well I tried my stock ecu and its the same result. Is there a chance both ecu's are bad?? But no I am doing it correctly. Take keys out of ignition, put the paperclip in the 2 pin, and put ignition on start. That didnt work so I grounded A13 and I got the same result, just solid cel.
Haha this is ridiculous. If it helps my car was running terribly in limp mode last week, couldnt rev past 3500 and car almost bogs when you touch the gas. But a couple days ago I started it and it just died and wouldnt turn over. My starter makes a noise, but I actually dont hear the fuel pump priming when its in the start position. Is there a chance the main relay can cause all this?? Solid cel and the symptoms that is.
Old Mar 20, 2007 | 04:24 PM
not all paperclips conduct a current - try a thin piece of wire or a 2 prong quick connector
Ive never tried grounding a13, so cant help you there
Old Mar 20, 2007 | 04:32 PM
Lucky-13's Avatar
wiring ended with the same result
Old Mar 21, 2007 | 01:54 PM
Lucky-13's Avatar
Default Re: Solid CEL on a B16 (YouvGotMail)
94civiccpe
Jul 18, 2013 07:48 PM
street_racer_271
Jun 11, 2012 07:53 AM
jtjtjt
22
Feb 17, 2012 02:46 PM
stunn'd
Jul 11, 2008 06:37 PM
blackeg
Apr 3, 2007 07:07 AM
