Speedometer not working!
Old Jun 10, 2012 | 10:12 AM
Shran29's Avatar
Icon3 Speedometer not working!
I recently bought a 95 Honda Accord EX manual transmission as my first car. The only problem was that the speedometer wasn't working. Everything else runs beautifully. After doing some research I thought I had nailed down the problem as a failed speed sensor, but after replacing it the speedometer and odometer still won't work! Can anyone tell me what the heck is going on and how to solve the problem?!
Old Jun 10, 2012 | 12:00 PM
igotthaspirit's Avatar
Default Re: Speedometer not working!
Most likely if you replaced the VSS then it is the gauge cluster.
Old Jun 10, 2012 | 01:26 PM
GhostAccord's Avatar
Does the Cruise control work? If it does then it is a gauge cluster or maybe a wiring issue between the VSS and the gauge cluster. If it does not work and you have already replaced the VSS, I would check the wiring and connector for corrosion or shorts (worn cut wires).
Old Jun 10, 2012 | 03:58 PM
Hidenplanvew's Avatar
Just ohm out the wires to make sure you have continuity from plug to plug
jdmkris
Sep 10, 2009 07:48 AM
JDM Dylan
14
Mar 5, 2008 09:11 PM
kamakaze1
Oct 27, 2006 06:31 AM
Jackadeal
Mar 10, 2006 03:18 PM
