A/C problem
Old Jun 7, 2012 | 11:02 AM
Spo427's Avatar
Default A/C problem
I have a '95 Civic w/ 1.5. I replaced; compressor, dryer, condenser, evaporator and thermal exspansion valve. Pulled vacuum for 45 minutes no leaks 1 hour. Recharged with 1.2 lbs (as per all data), and yet when the ambient tempurture is around 90, it does not blow below 60 (Robinair dial thermometer in vent). Any ideas, it appears the vent doors are closing and heater control valve moves.
Old Jun 7, 2012 | 04:05 PM
Zeusfire69's Avatar
Default Re: A/C problem
Pressure sensor(s)...sounds like that is the only thing you haven't replaced except for oriface tube.
Old Jun 8, 2012 | 06:37 AM
fungus mungus's Avatar
When this happened to me, it turned out to be the relay. Like the main relay, when it gets hot it stops working. Maddening. Swapped mine and it blew cold regardless of tge ambient temp.
fm
Old Jun 13, 2012 | 05:44 PM
Spo427's Avatar
fm
Old Jun 13, 2012 | 05:45 PM
Spo427's Avatar
Which relay? And where is it? Thanks, I am in FL and it is hot!
Old Jun 13, 2012 | 05:46 PM
Spo427's Avatar
Old Jun 13, 2012 | 05:49 PM
Spo427's Avatar
Are you referring to the low pressure switch? If not, where would it be located? I don't think there is an orifice tube, I did replace the thermal exspansion valve. Thanks for the reply.
Old Jun 13, 2012 | 05:50 PM
Donkey85's Avatar
there is no orfice tube on our kind of a/c setup... that is what the expansion valve is for.....
do you know if the compressor is cycling? if its not then id check the low pressure cycle switch for being faulty
Old Jun 13, 2012 | 06:28 PM
Former User's Avatar
When it's ~90F, measure the low and high side pressures and the vent output temp with the A/C on Max and engine idling at 1500 rpm.
Old Jun 15, 2012 | 11:28 AM
Spo427's Avatar
Old Jun 15, 2012 | 11:29 AM
Spo427's Avatar
Yes, the compressor is running and the clutch is engaged.
Old Jun 15, 2012 | 11:30 AM
Spo427's Avatar
Old Jun 15, 2012 | 11:32 AM
Spo427's Avatar
At 90 F, idle, full blast recirculating the low is 35, high 200-225 vent temp 60-65.
Blimp53
Honda Civic (2006 - 2015)
Jun 30, 2015 05:48 AM
taeright
Honda Insight & CR-Z Hybrid
Aug 14, 2013 04:43 PM
beat
Apr 27, 2009 09:16 AM
92lstcvc
Mar 23, 2006 07:56 PM
