Car died driving, Won't Start Now!
Old Jun 7, 2012 | 09:43 AM
MegaTwinky's Avatar
Default Car died driving, Won't Start Now!
I was driving down the street at like 35 mph and my car died. It has not started since then. It cranks but does not start. I have replaced the main fuel relay and distributor. I check the timing belt and its good. I have tried cranking the engine and I noticed the rotor won't spin. Why if the timing belt is good? Help!?
Old Jun 7, 2012 | 11:31 AM
fcm's Avatar
fcm
Old Fart
Default Re: Car died driving, Won't Start Now!
Sheer pin on distributor drive has "sheered", pull the distributor. 94
Old Jun 7, 2012 | 12:26 PM
MegaTwinky's Avatar
Sorry but I'm a bit of a noob, I know basic stuff. What's a sheer pin and where can I find it?
Old Jun 7, 2012 | 12:27 PM
kyden's Avatar
are you sure the timing belt is good? a lot of times it will just shear the teeth off the bottom.
Old Jun 7, 2012 | 12:37 PM
TheRealTegger's Avatar
1) If the starter operates and the engine turns, but the distributor rotor does not turn, then something really bad is broken.
2) The distributor is keyed to the camshaft with an offset slot and tab, so I'm not sure what a "sheer" (shear) pin is. The slot and tab normally do not break. Either your timing belt is broken, or a camshaft is broken. However, was there red dust inside the distributor?
3) By cranking the engine with the distributor cap off, you will wreck your coil (if you haven't done so already), so don't do that anymore. If you want to see if the cams are turning, remove the oil-filler cap and look in there while cranking.
Old Jun 7, 2012 | 05:11 PM
fcm's Avatar
fcm
Old Fart
Should have said sheer tabs, or maybe drive tabs...
and yes they do shear off, sometimes.
I agree, remove oil cap and see if cam turns, if so, it is a good bet distributor drive tabs have sheared off, or the shaft itself has broken.
Or you can just pull the distributor and see if the tabd are still there and if turning the tabs turns the rotor. 94
Old Jun 7, 2012 | 07:14 PM
MegaTwinky's Avatar
Attachment 275158
I check and the tabs are good. They are still there.
Old Jun 7, 2012 | 07:15 PM
MegaTwinky's Avatar
Could it be crankshaft position sensor if I checked everything else? Friend of mine told me it could be it.
Old Jun 7, 2012 | 08:53 PM
fcm's Avatar
fcm
Old Fart
If rotor is not turning, as TheRealTegger puts it, "something really bad is broken".
the rotor is "turned" mechanically, crank shaft drives the timing belt, timing belt turns the cam(s), cam drives the distributor shaft, rotor sits on distributor shaft, something has got to be broken.
Did you check to see if cam is turning, as suggested?94
Old Jun 7, 2012 | 09:01 PM
beecee18's Avatar
Wierd vooddo stuff man!
Old Jun 7, 2012 | 11:44 PM
Solster's Avatar
Check and Make sure belt is turning the cams as fcm said if the belt is turning the cam gears and the came shft is turning then the cam snapped off just befor the Dissy and you will need a new cam.
my bet is that you have a FRAM oil filter on the car. and Like fram filter tend to do it collapsed inside and stoped flowwing oil to the motor and siezed the cams to the head and ripped the teeth of the belt at the crank like this guys did.
https://honda-tech.com/forums/acura-integra-6/car-wont-start-3057606/
LS_Integra_94
Mar 14, 2007 07:15 PM
vega_ROCKS
Feb 15, 2007 10:23 PM
MAXFLOW2
Feb 23, 2005 11:50 PM
FDADGATE
19
Jul 4, 2004 04:44 PM
Yambor
Jun 23, 2004 08:45 AM
