Classic Hondas All Pre-1988 Hondas.
1982 Civic wagon Crank Pulley
Old Jun 6, 2012 | 02:27 PM
Neen's Avatar
Default 1982 Civic wagon Crank Pulley
I cannot seem to get the crank pulley bolt to budge...is this a counter-thread bolt?
Also is it standard to have the engine mount run through the timing belt cover? Seems like a bad design and was wondering if I had some weird one-off idea.
Old Jun 8, 2012 | 09:00 AM
Neen's Avatar
Default Re: 1982 Civic wagon Crank Pulley
Any feedback on this from someone with a 2nd gen Civic?
Old Jun 8, 2012 | 03:23 PM
83Wago's Avatar
Its right hand thread and they are terrible to get off because the motor rotates counterclockwise so you cant wedge a ratchet and bump the motor and there is nothing to stop the motor from turning. Maybe an impact, little heat, and couple taps may help. FYI if you get if off the torque is 80ft lbs when going back on.
Old Jun 8, 2012 | 03:41 PM
lazlong's Avatar
Good penetrating oil (not WD-40), 6ft breaker bar, and A LOT of grunting and straining. Or a 1" impact with an extension big enough to go outside the fender (you're never gonna get a 1" impact inside the fender).
bradley
13
Jan 9, 2012 02:12 PM
socialistic
31
Jun 26, 2011 12:54 PM
jlfrnce
Dec 4, 2009 07:48 PM
model x
Sep 30, 2006 09:38 PM
EvilPinkEye
12
Aug 2, 2006 11:51 AM
