96 gsr cam caps, cam journals order...
i have a 96 gsr engine my buddy was changing the headgasket and he forgot how the cam caps go back they have the numbers 4-1, 3 ,2-2. now we know that 3 goes in the middle we're just confused about the other two which looks exactly alike any help would be appreciated thanks, i've searched and all i can find are the cam seal replacements,
is the correct order #1 or #2
#1 dizzy 4-1, 3, 2-2 timing belt
or
#2 dizzy 2-2, 3, 4-1 timing belt
or
thanks for the reply dc4lsteg, can't see the numbers, see how the 2 middle cam caps looks exactly the same but they have numbers on em to tell em apart just need to see those, we dont want to mix up the caps since it can mess up the cams
[QUOTE=famous323;47448219]from dizzy side 2-3-4[/QUOTE
thanks for the reply just a quick Q is the order of the cam caps year specific?
i found and downloaded a pdf of a 94 integra manual and found the order
DIZZY 4-3-2 its page 6-77 on the manual weird
I just checked my factory manuals. The #1 cam holder on all engines is always at the timing belt end. #5 is at the distributor end. Now you know where #2 and #4 go.
Note that there are arrows on the holders. These must point towards the timing belt.
ok thanks for the reply guys, so its goin to be
Dizzy 2-2, 3, 4-1 TB
i will also post pictures of the numbers and arrows on the cam caps
if you put your caps on exactly as pictured above you will have them in the correct order. you cannot mess up if you do it just like the one above. they only go on in one orientation. the slits on the top of the cap face the timing belt side of the engine. there is your definite answer that was already given to you BUT you could not interpret it for yourself, so i did it for you. a picture is worth a thousand words goddamn.
im not hyper...the reason i said what i said, was because, after the picture was posted, you were still somehow confused on how they went together. i just wanted it to be crystal clear for you.
