Cam Caps numbers/ order?
Hey I pulled my cam caps off and want to make sure i get them back in the right order. I have 3 pieces, they have the numbers 2-2, 3-2, and 4-2 on them.
What order should they go in left to right? Also all the arrows should point right toward the cam gears right...?
the three inner pieces are what im talking about, numbered 2-2, 3-3, 4-2. 3-2 is the middle one, but i dont know if the left and right are 2-2. 4-2... or 4-2, 2-2.
Can someone help me out?
Re: (turbotime)
I remember doing this crap about a month ago. You should have labeled them, but I'll try and remember.
The arrows do point toward the timing belt. The numbers should look upside down when installed correctly.
4-2 is over by the distributor side
3-2 is in the middle
2-2 I think you can figure this out (is closest to the timing belt)
Be sure to torque them down according to the Helms!
Re: (turbotime)
The inside bolts (8mm)(12mm socket) should be 20 ft-lbs
The outside bolts (6mm)(10mm socket) should be 7.2 ft lbs
Tighten from the inside out and criss cross.
The Helms: Never leave home without it
