Help: 94 civic ex ej1 overheating
Old Jun 4, 2012 | 07:13 PM
ANNiHiLATORS's Avatar
Default Help: 94 civic ex ej1 overheating
Whats up got a 94 civic ex d16z6 5spd, it recently noticed the temp gauge got above normal, so decided I should change thermostat, after running it still did the same, seems to me like the fan is kicking on a little late, need help. Don't knw what the problem is, could it be the temp sensor on thermostat housing
Old Jun 4, 2012 | 07:22 PM
sillyboi's Avatar
Default Re: Help: 94 civic ex ej1 overheating
Did you bleed the coolant system after the thermostat replacement?
Old Jun 4, 2012 | 07:23 PM
Yah
Old Jun 4, 2012 | 07:32 PM
sillyboi's Avatar
It's possible is the fan switch (on the T housing). Just pick one up at the local honda dealer.. Or if you're low on cash, short the fan switch so it runs continuously.
Old Jun 4, 2012 | 07:36 PM
MikesEJ1's Avatar
I had the same exact problem on the same exact car (mine lol)
The coolant gauge would go up but stay in the normal range,checked my radiator cap and it was broken.changed that,bleeded the coolant and it got a little better.replaced the radiator bleeded the coolant again and it's been fine ever since
also replaced the thermostat for good measure
Old Jun 4, 2012 | 07:44 PM
I'm gonna try a new temp sensor they're $20 or so, hopefully that fixes the problem, if not i'll wiring the fan so it can run constantly.
Old Jun 4, 2012 | 07:53 PM
Former User's Avatar
First unplug the fan switch and jump the connector with a piece of wire so it will run all the time. If this does not prevent the overheating, then the problem is elsewhere.
Are you losing any coolant?
Did you bleed like this:
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Edwin Reyes
Jan 17, 2016 01:42 PM
HFpower
24
Sep 30, 2011 07:40 AM
yosuoh
Jun 18, 2011 08:52 AM
92fourdoor
11
Jun 15, 2008 04:56 PM
sloride
Jul 6, 2003 10:46 AM
