t70 turbo boost fitting
Old Jun 4, 2012 | 03:55 AM
skaraider's Avatar
Default t70 turbo boost fitting
OK, I have a t70 turbo but it doesn't have a fitting on the intake side for boost, ive been doing research on my own. and what has been showed is..................I can drill a hole on the pipe that feeds my intercooler with a fitting that goes to the boost controller.
Does anyone have a picture of their setup, before i start drilling holes in my pipes i wanna make sure im doing it correctly. Thanks
Old Jun 4, 2012 | 09:42 AM
skaraider's Avatar
Default Re: t70 turbo boost fitting
Also the top fitting on the WG goes to vaccum and the bottom goes to my Boost controller?
Old Jun 4, 2012 | 05:48 PM
rclark's Avatar
Top fitting goes to vacuum only if using an electronic boost controller. For manual, leave it vented. You can also use a vacuum source from your vac manifold for the a boost controller, to save drilling into the t70. That's a big turbo.... have you built a turbo car before ?
Old Jun 4, 2012 | 05:56 PM
TravisBiggie's Avatar
Ive read everywhere you run a line from the top of the WG to the boost controller, and the bottom vac line on the WG to the compressor housing
Old Jun 5, 2012 | 06:40 AM
dpetro1's Avatar
there are not general rules for isntalling a boost controller. you need to follow the manufactuer's instructions. what brand controller are you using?
as for your boost source, you can use an IC pipe for a boost reference. you can drill and tap for the fitting or weld a fitting on.
Old Jun 6, 2012 | 03:26 AM
skaraider's Avatar
Dpetro thanks alot
2ndchirp
May 24, 2009 08:14 PM
B18C_EJ8
Feb 23, 2008 03:10 PM
ericstambaugh07
Jul 4, 2007 11:13 AM
It's*BOLO!!
Apr 10, 2003 07:54 PM
Mucackus
Apr 26, 2002 08:45 AM
