just put my turbo would it turn on
Old Jun 3, 2012 | 06:11 PM
1999EK9Vtec's Avatar
Default just put my turbo would it turn on
hey honda tech, i just finish putting my turbo in my car i just have few question,
befor i start my setup
b18c1 gsr everything full motor with tranny
motor stock just a few built on part
arm fuel rail with rc1000cc
skunk2 intake manifold with 68tb
3inch pipe with hks high power
tray stock as now stock clutch
apr head stud with oem gasket
turbo
GOSPEED TOP MOUNT CAST IRON MANIFOLD
3 INCH DOWN PIPE TO VBAND
HOLSET HX35W 7 blade
tial wasgate with a 11 pound spring
greddy blow off valve
ecu p72 stok gsr
my question is on thursday I'm gonna get it tune and is 1 hour alway from my house but my stock injector 2 of them felt and the cover thing broke and idk if the car would turn it with it didn't try it cause I'm still putting the piping for the intercooler ,
so can i take it to the tuner with my 1000cc with out giving my any problem just for i can get it tune or i need to get stock injector and when they about to tune it that when i can put on the 1000ccc
Old Jun 3, 2012 | 06:14 PM
Dc4LsTeG's Avatar
EK9
Default Re: just put my turbo would it turn on
You cant run the 1000s with a stock ecu. Maybe get a basemap from your tuner to get you to the dyno with them
Old Jun 3, 2012 | 06:30 PM
ok so getting a basemap yes, thanks you a lot with the two injector mess up the car isn't gonna turn on correct? so I'm gonna see with the tune can give me a baseman to get to the tune,
cause I don't wanted to buy 2 stock injector for 80 that I would never use again
Old Jun 3, 2012 | 06:39 PM
dk=gsr's Avatar
is it the saturated or peak and hold injector???
i have 3 gsr injectors that are still good...
the other one has a broken orange tip too.
so if you only need 2 ill give it to for 15 shipped.
Old Jun 3, 2012 | 06:40 PM
dk=gsr's Avatar
but if you want to run the 1000's than yes contact your tuner and ask him to send you a map to run your 1000's.
Old Jun 3, 2012 | 06:44 PM
are they obd1 I would buy it for 15
Old Jun 3, 2012 | 07:31 PM
dk=gsr's Avatar
i got obd1 and obd2.
Old Jun 3, 2012 | 08:08 PM
Blove1991's Avatar
How much power are you trying to make? Hope it is not much considering you have a stock clutch.
Judging by the 11lb spring in the WG you are shooting for at least 300.
Also as a side note if those RC1k injectors are low resistance then you will need a resistor box as well.
Old Jun 3, 2012 | 08:14 PM
Freshdot's Avatar
how the hell did anyone make sense of that op? further more why are you running 1000cc injectors on this build?
come get these 310's off me lol
Old Jun 3, 2012 | 08:54 PM
artie89's Avatar
make sure you use a resistor box with your rc1000 if they or Low Impedence Type injectors so you dont burn them out
Old Jun 3, 2012 | 09:02 PM
it came with the turbo set up, I bought it off boy so, I'm just gonna use it for now and in the future I'm gonna build my motor later on but as of now it just gonna be this set it...
Old Jun 3, 2012 | 09:07 PM
my clutch set up gonna be in 3 week act 6 puck with PP and light flywheel with obx LSD
but more power as of now around 300, and future hopefully 340-370 I'm be happy
and I do have the resistor box, thanks for the info guy I will post pic
Old Jun 4, 2012 | 10:12 AM
Freshdot's Avatar
i live in the same area as you, if you need any work done let me know.
Dat_Hatch
Apr 30, 2014 02:22 PM
sdobson910
Apr 20, 2011 03:59 PM
Katsuz
Honda Civic (2006 - 2015)
Jan 28, 2011 11:04 AM
96accordsir
Mar 1, 2010 10:57 PM
crx1967
May 26, 2005 09:49 PM
