So my car was stolen and recovered. ??
Old Jun 3, 2012 | 05:58 PM
roboda's Avatar
Default So my car was stolen and recovered. ??
So my car was stolen at my apartment complex late friday night/sat morning. My car is stock and falling apart. Either way I picked it up today after it was found by the police department 9 miles away from me near a play ground. The ONLY thing wrong/stolen was my back pack. My question is how did he start my car ?? If he would of took it and dropped it back off I would of never noticed, nothing is out of place just a missing back pack.
Old Jun 3, 2012 | 06:49 PM
variable's Avatar
Default Re: So my car was stolen and recovered. ??
If its stick shift, he could have just had some one push it and then pop the clutch
Old Jun 3, 2012 | 07:15 PM
90_EX_Civic's Avatar
if your car didn't have an alarm, he probably just used a shaved down honda key.
Old Jun 3, 2012 | 11:22 PM
3rdtimecharmer's Avatar
10 Year Member
under steering column, pull off plastic. 2 screws on side to ignition. Stick 4 head screw driver in, turn to start..
Old Jun 4, 2012 | 08:03 AM
hbcrazy88's Avatar
WTF are you doing dude...... maybe you should keep that information to yourself instead of telling people how to steal cars. Think before you speak and in this case type.
Old Jun 4, 2012 | 08:13 AM
beecee18's Avatar
Like everybody already doesn't know how to do that noob
Old Jun 4, 2012 | 09:45 AM
Recaro's Avatar
Seriously dude chill out. Anyways most likely they used a master key because I know them thieves are not gonna put ur steering column back together the way it was. Did you have any security on it, a clutch lock can sometimes be a life saver 20 bucks at autozon.
Old Jun 4, 2012 | 10:35 AM
wanabebuff's Avatar
As shitty as it is, a worn out honda key will often unlock/start another car that uses the same type of key..... I have started my friends car's several times and opened junkyard car doors with my keys......
Really makes you take a close look at your added security, especially knowing your door locks and ignition locks do very little to deter a thief.
Old Jun 5, 2012 | 06:20 AM
collkid's Avatar
Fuel Cut-off. Takes 30 minutes but saves your car...
Old Jun 5, 2012 | 09:09 AM
akrite's Avatar
Layers of security always help.. fuel cut off, hod latch relcation/ block off shield, main relay cutt off are just some examples
Old Jun 5, 2012 | 10:21 AM
90efb16's Avatar
anything in the backpack?
Old Jun 5, 2012 | 10:42 AM
speedooo's Avatar
It's not rocket science, there's only 2 screws that hold the key cylinder to the ignition harness. Remove the key cylinder and you can start your car with a flat head screwdriver.
Civicthusiast
Audio / Security / Video
33
Apr 21, 2009 07:27 PM
zak88lx
Jul 20, 2007 12:49 AM
slkleltlclh
38
Dec 1, 2006 08:08 AM
sohc_coupe24
31
Sep 11, 2006 05:55 AM
GoLowDrew
23
Mar 4, 2003 04:38 PM
