obd1 motor to obd 2 crank position sensor need help fast
i just did a motor swap a d15z1 with a z6 head im using the obd 2 harness with an obd1 conversion harness i keep throughing a ckp cel can i just use the 1.6 obd2 oil pump and crank gear neeed help fast
Every were I'm reading I'm hearing that on an obd2 harness th cfs and cps are integrated I took the guts out of the obd2 dizzy cause they are the same and put it in an obd1 housing I under stand hat wither obd1 it picks up the signal for the cps from dizzy i might need a cps or cfs bypass
no bypass needed, all wires and sensors that are needed are already inside dizzy and wire harness
my first car was a 91 civic, i did a dpfi-mpfi, obd0-obd1, p06 ecu tuned, and a obd2 '96 ls swap soldering a obd2 dizzy plug and obd2 injector plugs on chassis harness. it worked fine no codes. later did a lsvtec so i bought a 96 gsr dizzy it on there no codes
oh this was all on the stock obd0 harness
only wires added was for dpfi-mpfi swap
please post the cel code number you are getting. i assume its code 9? and obd1 ecu would not look for the CKF sensor so it would have to be an issue with the dizzy
here is a dizzy pinout
sikcrx80
May 1, 2023 05:16 PM
EJgsr
Oct 19, 2006 07:54 AM
