burping coolant.
Old Jun 3, 2012 | 08:22 AM
lavos635's Avatar
Default burping coolant.
i was doing research on an erratic idle, cleaned my iac valve 3 times, got a new iac valve, and now im seeing where i should have burped the coolant.
my overflow is always empty i check the radiator and its always full and my guage is always where it should be. tomorrow ill pick up some honda coolant and see whats up.
what all will i need and wheres the bleeder screw?
Old Jun 3, 2012 | 08:26 AM
mish__'s Avatar
Default Re: burping coolant.
What honda?
What motor?
What year?
Old Jun 3, 2012 | 08:31 AM
motegicivic's Avatar
Like above need year and model. 96 and newer no bleeder screws.
Overflow always empty, that is not a good sign.
In the stickies there the bleed procedure, do that refill the radiator and the overfill to right level depending on hot or cold.
I would get a new oem radiator cap, I am wondering if the system is not be pressurized right.
Old Jun 3, 2012 | 08:36 AM
lavos635's Avatar
its an em1
Old Jun 3, 2012 | 08:41 AM
lavos635's Avatar
i also didnt mention iac valve fixed my problem with the codes, and the idle is almost where i want it. its a little high when it starts up and doesnt idle back down quickly like it used to.
Kasheena Winn
Feb 17, 2018 01:07 PM
Sksbuyer99
Feb 13, 2017 03:41 AM
variable
Aug 18, 2006 05:03 PM
loosestring
Nov 13, 2005 09:53 AM
SeaBass
Dec 18, 2003 03:27 PM
