Low idle....help please
Old Jun 1, 2012 | 09:10 AM
97sohc_d00d's Avatar
Default Low idle....help please
Okay i have a 97 ek hatch with a y7 block and z6 head...since the swap i have been having tons of issues with the performance of the engine. I have it timed at tdc head and block with adjustable cam gear...my issue is it doesnt want to idle above 500rpms then it wants to drop and shut off on me i have messed with the ignition timing a thousand times and cannot seem to figure out why it wants to idle so low... if i drive it its okay once i get up to 3000rpms then it will drive fine. Any help would be greatly appreciated
Old Jun 1, 2012 | 09:22 AM
EJ8_Man's Avatar
Default Re: Low idle....help please
Sounds like your IACV is not functioning correctly. Have you tried cleaning the throttle body and IACV?
Old Jun 1, 2012 | 09:24 AM
Former User's Avatar
P28 ECU? What's the need for an adjustable cam gear?
Use a timing gun to set the ignition timing to spec with the service connector jumped and a friend holding down the throttle pedal to keep the engine rpm at spec idle speed.
Then adjust the idle speed to spec.
Old Jun 1, 2012 | 09:44 AM
I havent cleaned the iacv but the throttle body was clean i took it off to inspect in...what do i clean the iacv with? And yes its a p28 and i got the adjustable cam gear cuz i read all over the place it was needed to reach true time but later found out that was false
Old Jun 1, 2012 | 09:48 AM
JuggerNaut-CTR's Avatar
Here is a great write-up on finding whats causing your bad idle.
http://www.superhonda.com/forum/f55/...oblems-259965/
Old Jun 1, 2012 | 09:52 AM
Originally Posted by 97sohc_d00d
...i got the adjustable cam gear cuz i read all over the place it was needed to reach true time but later found out that was false
Then first remove the adjustable cam gear and install the stock one. Then do the other things I mentioned, as well as clean the IACV as others have said.
Old Jun 1, 2012 | 12:56 PM
Had it timed my buddy runs a shop we checked the timing its all good now when we unplugged the iacv it stayed running he said its supposed to shut off he said its no functioning properly so time for a new one
Old Jun 1, 2012 | 01:07 PM
This test^ doesn't necessarily mean the IACV is bad - it also could be dirty or have a bad wire or even a bad ECU.
What ECU? Any CEL codes?
Old Jun 1, 2012 | 01:38 PM
Its a p28 and no cels
Old Jun 1, 2012 | 01:45 PM
EJ8_Man's Avatar
Yes please clean it with brake cleaner or another solvent and check the connection before spending money on a replacement
Old Jun 1, 2012 | 02:05 PM
Yep^
Also consider that the idle speed is set too low.
Old Jun 4, 2012 | 12:41 AM
Would purple power industrial cleaner be too strong to clean it? And i had my buddy set the idle speed
Old Jun 6, 2012 | 01:38 PM
The iacv was not very dirty at all my only other thought could be...im running the map sensor from the y7 and the purge valve from the y7 any way this could be affecting it
Dylanthoms
Apr 24, 2018 08:52 PM
boostedjdmdc2
Dec 24, 2007 03:38 PM
B16CRXT
Jul 19, 2004 11:06 AM
bleebdat
Jan 7, 2003 10:52 AM
TheIntegraGuy
Dec 28, 2002 06:49 PM
