Help with rough idle!
Old May 31, 2012 | 04:30 PM
Azimmer's Avatar
Default Help with rough idle!
So my issue is when the car fully warms up and I drive a good distance and then come to a stop my car with idle really rough then go back to normal, sometimes it dies, what's weird is it doesn't do that when the ac is on. I'm not throwing a check engine light and it's a stock d16y7, any ideas?
Old May 31, 2012 | 05:10 PM
motegicivic's Avatar
Default Re: Help with rough idle!
Car and model? Stick or Auto?
Doesn't do it when AC is on because the idle speed goes up with the AC on and prob hides the problem.
When is the last time you did a simple tune up. Cap, rotor, wires and plugs and for good measure fuel filter.
I would only use NGK plugs and OEM parts.
Old May 31, 2012 | 07:17 PM
dunkingmofo's Avatar
could be a dirty iacv or vacuum lines could be in the wrong place or idle screw could be too closed..theres a lot of things that could affect the idle like that.
Old May 31, 2012 | 08:19 PM
Azimmer's Avatar
98 lx 5 speed, car has done it since I have had it, recently I have put new spark plugs and an wires in, I am thinking it could be the fuel filter, I checked for vac leaks and non
Old Jun 1, 2012 | 06:56 AM
if it was the fuel filter and been doing it since you got the car then it would get progressively worse. try messing with the idle screw and possibly cleaning the iacv.
Old Jun 1, 2012 | 08:04 AM
Former User's Avatar
-Check the cap and rotor. How old are they?
-Check the coolant level and top off the radiator and reservoir, if necessary, and bleed the cooling system.
-Adjust the idle speed - see diagram in FAQs sticky.
piepans
Honda CR-V & Element
Oct 27, 2014 08:54 PM
90crvtec
Jul 5, 2005 08:09 AM
jaycapz
Sep 1, 2004 02:43 PM
