Catch can fittings to block..?
Old May 31, 2012 | 04:35 AM
dc2lsvtech's Avatar
Default Catch can fittings to block..?
I have been doing alot of searching on this forum and I understand everything for the catch can install except where do the fittings for the block go on the b-series engine.?? I am in the process of collecting my parts for my build and this is the only thing Im wondering...thanks
Old May 31, 2012 | 05:16 AM
boosted_D's Avatar
Default Re: Catch can fittings to block..?
What kind of power are you going to be making?
That kind of set up is really only needed for 400+ whp set ups.
If your below that, all you need is a vented catch can with one line to the black breather box on the block, and one line to the valve cover port.
Putting in the dual block ports sometimes causes more problems with oil over flowing into the catch can, that set up is really only good for race cars, not daily drivers.
Old May 31, 2012 | 08:21 AM
dc2lsvtech's Avatar
I am running a full build 500+ on street and 700+ for strip...
Old May 31, 2012 | 08:28 AM
dc2lsvtech's Avatar
thanks guys I actually found a page on here that shows me....
Old May 31, 2012 | 10:03 AM
sc34dc4's Avatar
They go where the 19mm hex plugs are on each side of the oil filter.
Old May 31, 2012 | 10:20 AM
Steeve_Civic's Avatar
How many fitting are going to run?
I asked me a question that if I remplace only the OEM Black box on the 2 others.
Old May 31, 2012 | 10:46 AM
dc2lsvtech's Avatar
Thanks guys I found the spots appreciate the help...
Honderachinaldo
Jul 16, 2019 08:28 PM
ko2performance
Mar 12, 2016 07:09 PM
67mmlsv
Oct 22, 2012 12:23 PM
scspeed
May 1, 2008 05:15 PM
bleedblue94
Sep 3, 2004 08:49 PM
