Wastegate Plumbing Question!
Old May 30, 2012 | 02:39 PM
ThE HeLLRaZoR's Avatar
Default Wastegate Plumbing Question!
Setup is Twin Tial 44mm Gates. I have a bunch of -6 AN Fittings and some -6AN Hose laying around. I'm thinking about Plumbing the Vacuum on the Wastegates with this stuff(Cuz it will look GOOD). Most Vacuum Lines are 2.5-3mm(Inside Diameter), This -6AN Hose is more like 5.5mm(Inside Diameter). Being that there is gonna be a long run from the Manifold, to Solenoid, to the Gates. Could this cause a Problem? It's been Raddleing around in my head and it seems it could Rob my Vacuum and possibley affect the reaction time with anything Vacuum refernced?
Thanks in Advance for any Advice given
Old May 30, 2012 | 04:03 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Wastegate Plumbing Question!
why change what already works.
Use that -6 for a fuel filter replacement for an inline filter.
If you want some bling, the push locks are baller
Old May 30, 2012 | 04:57 PM
SovXietday's Avatar
It'll work fine, if you really want to use 6AN for something like that.
Old May 30, 2012 | 08:30 PM
I have a sick fuel setup already haha. Thing is I have this -6AN stuff that was gonna go on my Uncles Fiat. So I wan2 put them to use. But, if it's gonna cause any sort of problem big or, small, then I won't use them. But, i'm not experianced with what works and what does not yeat;/
Old May 30, 2012 | 09:11 PM
Gunmetal_B20_Hatch's Avatar
-6AN is ridiculous... I would go with -3AN. I would be concerned about a delay in the signal with that much volume in a vacuum hose.
FYI, -6AN is 3/8" which is around 9.5mm
Old May 30, 2012 | 10:20 PM
Well that confirmed what I already knew. I will go for something smaller. I'm just tired of looking at $130+ worth of -6AN Fittings and Line lol... Thanks for the Advice
Old May 31, 2012 | 09:25 PM
Well here is what I came up with. -3AN, RuFF DrafT, should work.
GsrIntegra789
May 6, 2008 06:05 PM
oneiro
Nov 3, 2006 11:06 AM
rocket256
Mar 13, 2005 03:38 PM
teal EJ1
Aug 24, 2003 09:19 AM
Integra_Boi
Jul 20, 2003 08:28 PM
