ignition module?
Hello honda tech i come for your help again.my last problem with the fuel pump is fixed i am getting fuel so now it would be spark.i pulled apart my distributor to look at my icmand realized 2/3 wires were plugged in the other was cut. The engine is a 96 b18c r. i had this engine running fine in my last cars, so i am at the question is should i splice and put a connector on i have pictures for you guys.
the ignition module as i pulled the distributor off
the 3rd wire that has obviously been cut
the ignition module as i pulled the distributor offthe 3rd wire that has obviously been cut
H23vtecEG
Oct 14, 2003 05:02 PM
