MSD distributor wiring help???
I'm trying to hook up an MSD TD-42U distributor with an MSD SCI ignition module (PN 6300) and an MSD Blaster SS coil (PN 8207) on a D16Z6. Most of it I have figured out, but there are a couple of things I'm not sure of. There's a yellow/green wire and a yellow/black wire coming from the distributor that is cut. Also, I'm not sure how to wire the SCI, either. There's a purple wire and a green wire that share a harness that is supposed to be hooked up to a mag pickup or a distributor wire. Alternately, there's a white wire that goes to the "points or amplifier output (connects to yellow wire on timing accessories)". Has anybody ever hooked up anything like this?
Modified by eg6imola at 12:46 AM 5/25/2008
Modified by eg6imola at 12:53 AM 5/25/2008
Modified by eg6imola at 1:02 AM 5/25/2008
