Difference Between an AT and MT Rad?
I`m going to be ordering my aluminum rad for my EJ1 in the next week. I have a few in mind but they say MT only. Is there a differenct between the AT and MT rads? I have an EJ1 with an auto D16Z6..
pm4nudes
Re: Difference Between an AT and MT Rad?
But why do you need a radiator that has a higher cooling efficiency? Or are you just looking for a smaller radiator to make room?
The Grumpiest
FYI: This is the one I`m looking at. It says MT, so I`m not sure if it will or will not work with my ej
The Grumpiest
You could but you will probably get the same result, reduced cooling capacity. The shroud is what makes the fan more efficient. If you do, don't throw the old fan away.
Im not knocking the fact that it's an auto. Mine is auto. It's just that there is no performance reason to do this.
If it's just for looks then you will have to do as stated above and run an external ATF cooler. Good luck
sktyrhrtout
12
07-16-2009 03:37 PM
deeweezy187
01-05-2007 03:26 PM
sleepyhamsterlx
19
08-20-2003 03:24 PM
