Pulling the engine without the trans
I looked on the FAQ thread about pulling the engine and it said that you have to pull the transmission out with the engine. I was wondering if I can pull the engine and leave the transmission in it? Also where is a good place to chain the engine the lift it out?
If it's an automatic it can be done. If it's a manual then no you need to pull both. It's definitely easier to pull both together as a unit though.
X6 pull the Trans with it. As for where to mount the chain, I use the 17 for the Trans to block bolt and I use the 14mm hole in between intake mani and timing belt right below the vc
