code 9 cyp?? h22a4 prelude
I have a 4th gen prelude si swapped with a h22a4.. my problem is wen I plug in my chipped obd1 ecu, I get a code 9 cyp.. I have a spare ecu (p14) and wen I use it I don't get that code 9 and the car runs fine.. help?? Ecu is newly chipped and works perfectly in my friends..
where did the harness and the dizzy come from .. what car ? year ? if you used the obd2 harness there is your problem .. the a4 motors had triggers on the crank that mount on the oil pump the the h22a all the pick ups are contained in the dizzy itself .
Also I read that ckp was on the oil pump on obd2 h22 and cyp is in the dizzy.. in the post below
https://honda-tech.com/forums/showthread.php?p=45364125
My friend has a h22a but his distributor is external coil.. im gonna try a new one, if it doesn't work or if it does ill repost the results.. I wanted to know before I bought this also, will the Jdm td-60u dizzy be ok to use? Is internal coil which is wat I need since I dnt have the external set up.. it is obd1
Can you take a picture of the plug and wires coming out of that dizzy that you have? I wonder if something is missing in the JDm dizzy that your US ecu is looking for.
I'm assuiming you had the H23 beforehand, is the H23 dizzy still around? That should work just fine if you still have it (external coil and all)
][/QUOTE]
I think u are misunderstanding.. the distributor im using is the h23 one, which is in the pic .. but there's no plug for the extra coil on the cap.. My car is not set up at all for an external set up.. plus td-61u's are all external.. idk why this one has a diff cap.. I was going to buy a Jdm dizzy because that for sure is internal (I dnt have the external set up) and with it being new, would maybe get rid of the code since everything will be inside it never used.. I think my h23 one was tampered with before I got it
I think I found the problem.. this distributor looks like it was converted, or at least tried to be converted .. it wasn't originally internal coil.. im going to see if my new one fixes the prob
Yeah theres no such thing as a USDM Prelude that came from the factory with an internal coil dizzy. The dizzy casisngs though for the most part are the same so I would say that someone has taken it apart and pieced their own setup together which is why the part number appears correct. Doesnt mean you cant get it to work that way but I am guessing theres a sensor inside there thats missing. Have you taken it apart? There should be 3 sensors inside and 3 corresponding trigger wheels. You probably also have an altered wire harness. Might be a mess to sort this out! You should be able to source a factory (accord) obd1 internal coil dizzy... if the wiring is correct that might solve your problem. If it doesnt there is probably a wiring issue to sort out as well (something that didnt get hooked up)
Fixed.. messing with the wiring on the dizzy and the code went away.. going to change the distributor so it doesn't come back.. did the pressure switch bypass and nd now vtak yo lol jp thanks guys.. dizzy was the problem
