ls or gsr for sleeving?
Searching would be the answer...
It depends on what setup you have or want to run. Think about it.
GSR already has a block girdle. Minimal deck height differences. Depending on if you want the 87 or 89mm stroke would be another factor if buying a complete short block. GSR would accept a VTEC head with out a conversion kit. There are many factors. Since you didt give ANY information on the build desired I would highly recommend you stick to D15's.
The gsr block has more webbing so technically its a little more sturdy but all in all peopel have been sleeving ls and gsr blocks for years and one fdoesnt perform better than the other. The girdle isnt nessesary but a nice addition. if your going vtec you wont need a conversion kit but againt his is all minimal stuff. the crank can be used from either block and put into either block so that doesnt make any difference. once a b series block is sleeved and done correctly its close to bulletproof reguardless of b18b or b18c
ABCVTEC
14
Nov 15, 2006 08:59 AM
jamal-188
Apr 29, 2002 05:40 AM
