Question on vibration from b-shaft delete
Old May 21, 2012 | 02:50 PM
Rob97'SH's Avatar
Default Question on vibration from b-shaft delete
Those that have deleted their balance shafts. Does it affect idle quality much? Would adding a shock mount like this http://www.andysautosport.com/honda/...i00204706.html
help with vibration?
Old May 21, 2012 | 05:00 PM
gstrudler's Avatar
Default Re: Question on vibration from b-shaft delete
That's a torque damper and would make it worse if anything. The torque damper is designed to allow less engine movement under acceleration. It acts as a stiffener directly between the block and the chassis, thereby also transmitting vibrations directly to the chassis as well.
Old May 21, 2012 | 05:04 PM
Wing8806's Avatar
balance shaft delete
75a or higher mounts (even filled mounts)
engine stiffener like the one you posted or the one on ESP bars
Will all create more vibration in the cabin. There's really nothing you can do about it since the factory components are there to ease this vibration and make for a smoother ride. Removing/swapping any of the above do away with that comfort.
Old May 21, 2012 | 06:52 PM
typemismatch's Avatar
Honda owns me
I only notice the vibrations as being bad at idle and around 3k RPMs, I have hasport mounts, b/s delete and traction bars, but no torque damper.
Old Jun 9, 2012 | 06:22 PM
StevenBoost's Avatar
lil vib is okay
hondaman211
Jul 10, 2017 09:51 AM
raverx3m
Jan 6, 2016 08:32 PM
SoullessJapaneseMachine
Jul 31, 2008 09:43 AM
Agent Zero
Sep 15, 2004 07:26 PM
White HB
May 15, 2003 05:47 PM
