oil restrictor
Old May 19, 2012 | 01:04 PM
MurtazaDSM's Avatar
Default oil restrictor
I got a new ebay t3/t4 turbo for dirt cheap of cl. The guy gave me the oil feed and drain adapters. The adapter on the feed looks small and I was wondering if it is already restricted since the hole is really small or do I still need a restricor
Also there is a screw looking thing with a hole in it inside the oil feed part of the turbo, is this also a restricor? Should I take it out? The second pic is with the screw taken out
Old May 20, 2012 | 01:11 AM
MurtazaDSM's Avatar
Default Re: oil restrictor
anyone
Old May 20, 2012 | 08:45 AM
TheShodan's Avatar
Moderator
you will kill your turbo using that thing.. You will completely starve it of oil. throw it away.
Check oil pressure at cold start first. typically only after 80-85psi oil pressure is one needed on name-brand turbochargers.
If you need a restrictor, get a proper one.
http://www.brfittings.com/index.php?...&product_id=91
Old May 20, 2012 | 08:55 AM
xile6's Avatar
The one with the flange looks to small. Either way only use one of them.
4tika4
Mar 28, 2012 04:41 AM
crvtkllr
Oct 22, 2006 01:22 PM
Boosted2K
Jul 10, 2006 09:47 AM
ninja8oi
Jan 8, 2004 06:44 PM
BLKMamba
Aug 21, 2001 07:47 PM
