small exhaust for my turbo crx!
Old May 17, 2012 | 06:56 AM
whitevteckiller's Avatar
Default small exhaust for my turbo crx!
good evening guys!i prepare my crx with b18c engine and precission turbo 62/65 ball bearing and compression 10/1 and question is if I put a small exhaust, the car it delays it opens turbo???wants more compression???my project prepared for 700whp!the cams is b16b!I will have problem??? aim my they is to have full boost in 4300-4500rpm!thank you for your time
Old May 17, 2012 | 07:14 AM
Default Re: small exhaust for my turbo crx!
i dont want to delay after the 4500rpm! with small exhaust it will lose a compression?I ask because my blok it turns 9200 real! if it have full pressure in 5500-6000 i change gear 9200!Ηence the spectrum of turbine they will be little
Old May 17, 2012 | 08:25 AM
FastEg6's Avatar
No idea what you said.
Old May 17, 2012 | 08:36 AM
underpressure02's Avatar
I tried to put your post in google translate and that didn't even know what you said.
Old May 17, 2012 | 09:32 AM
MR.johnson's Avatar
Lol go to his thread in the transmission section. Omg.
Old May 17, 2012 | 06:03 PM
hondamn1320's Avatar
Yes, if you use a small diameter exhaust your setup won't be efficient. It will produce full boost later, it will create more heat, and make less power.
Old May 17, 2012 | 06:43 PM
Ron Burgandy's Avatar
Turbo applications typically want larger exhaust. 3" for sure. If you want the turbo to spool up quicker, I would recommend a smaller turbo or a bigger block....
My best answer for what I assume you are asking.
good luck.
Old May 18, 2012 | 01:52 AM
sorry my apology in English they is not also so much good!i want to put no small diameter exhaust i want small length exhaust(short)!as many setup in USA you have that come out from the bonnet!i ll have problem in full boost????thank!!! sorry for my english!
Old May 18, 2012 | 02:49 AM
89efhatchy's Avatar
You want an uppipe? Coming through the hood? Why do you think that will give you problems if it works for us in the states?
truesleeper
Apr 14, 2005 07:03 AM
love2xlr8integra
Aug 11, 2004 09:43 PM
sicivic12
May 17, 2004 04:57 PM
spiveslude
Feb 26, 2003 05:35 PM
Acura97GSR
Sep 6, 2001 03:15 AM
