Precision exploed? What would cause this?
Old May 16, 2012 | 02:56 PM
B18c1turboedEK's Avatar
Default Precision exploed? What would cause this?
Just wondering?
Old May 16, 2012 | 03:02 PM
JustOneOrTwoPosts's Avatar
Default Re: Precision exploed? What would cause this?
from the pics, it looks like the hit from the wall crushed the inlet pipe and maybe caused excessive heat because turbo was spooling but air was going nowhere. Just a theory..
Old May 16, 2012 | 03:03 PM
94turbosi's Avatar
From what it looks like ... Possible from the front end collision. Turbos where spinning at such high rpm , exhaust wheel probably broke right off.
Dc4LsTeG's Avatar
EK9
Maybe the wheel coming loose and destroying everything?
Edit above post
Old May 16, 2012 | 03:06 PM
Turbo exploding caused the accident.
Old May 16, 2012 | 03:14 PM
tepid1's Avatar
Ask miller. Happened to him if I remember correct.
Old May 16, 2012 | 03:20 PM
01DC4's Avatar
Does this make you want to spend $3,500+ on a PTE turbo, That makes the same power as BW or Garrett turbo's? lol
Old May 16, 2012 | 03:21 PM
SPOOLINmatt's Avatar
how the hell did the turbo exploding make the driver turn another direction or the rear end slide out from under him?
I'm not saying the turbo didn't explode cause its happened but this is a little out there, a turbo exploding causing a wreck?
Old May 16, 2012 | 03:26 PM
twkdCD595's Avatar
That is Ray Jr's car on yellowbullet. From reading about this and his posts. Those are promod 88's he bought in 2010 during the time there was some problem units, which Precision has since corrected. He was unaware of there being issues with that date range of production or of them being units with a recall on them.
Also from what I read Precision is taking care of him and upgrading him to all the newest stuff and s/s housings.
The problem units were on a group of promod 88 models from late 2010, not every Precision turbo. Again from what I read, they got some bad wheels that made it through balancing and such but where coming apart once they were in use seeing some heat cycling. Again, they have since correct this and look to be taking care of anyone who got some from that bad batch.
(In before the made in China claims start getting thrown around or the Precision haters file in to tell us how their turbo failed.)
Old May 16, 2012 | 03:27 PM
Thats what he said on Yellow Bullet.When explode oil and debris went under the tires causing him to loose control of car.
Old May 16, 2012 | 03:28 PM
01DC4's Avatar
Oil on the tire's? Shrapnel blowing a tire?
Old May 16, 2012 | 03:30 PM
Got traction's Avatar
rebuilt unit without balance? excessive shaft play?
Old May 16, 2012 | 03:40 PM
just didnt look like there would have been much oil from that.
Old May 16, 2012 | 03:52 PM
twkdCD595's Avatar
Looking at the downpipe you can get an idea of how much sprayed out. I imagine it does not take much oil at that power level to have it break traction and have it driving into a wall.
Old May 16, 2012 | 03:53 PM
nonvtecallmotor's Avatar
Huh? Really? 90psi of oil and a -4an line?
We had a PM88 brake the shaft on the dyno....
Old May 16, 2012 | 04:26 PM
YZFR6's Avatar
Happened to Tim Lynch in his new Vette too... I would still use their turbos, just because things happen so far I've had 3 PTE Billet turbo's and no issues. I'm going to be getting another one for a different project.
Old May 16, 2012 | 04:48 PM
miller's Avatar
yes it did and it happened in the development stages of what is now known as the "7285" I have tested tons of combos with precision, some work and some dont but we keep pushing forward to further the development.
You think this statement is true? What do you have to stand behind this statment? I have tons of data but my data is bias, why not ask around and get an unbiased review.
Old May 16, 2012 | 05:05 PM
DraginX's Avatar
I don't think there is a manufacturer our there that can honestly claim they haven't had failure. At 80+ Psi and 2 years of service those turbos have seen some serious abuse.
Old May 16, 2012 | 05:06 PM
hannslebo's Avatar
Garrett FTW.
Old May 16, 2012 | 05:07 PM
heavy duty's Avatar
**** that looks like a 6an line thats alot of oil
Old May 17, 2012 | 04:53 AM
agreed
Old May 17, 2012 | 06:13 AM
vtekthis's Avatar
chinese wheel?
Old May 17, 2012 | 10:00 AM
miller's Avatar
Originally Posted by vtekthis
chinese wheel?
Chinese rods in your engine? That might explain it.
Old May 17, 2012 | 10:54 AM
vtekthis's Avatar
cant keep the chinese in anything!
Old May 17, 2012 | 12:04 PM
eg_YANG's Avatar
Chinese food
