Tune question regarding injectors
Old May 16, 2012 | 10:12 AM
Fnix's Avatar
Default Tune question regarding injectors
I have dsm 450 injectors with a resistor box. I had a turbocharged car with a tune. I took everything turbo out and now run a stock basemap but have my 450 injectors still. Would running these on my now stock base map flood my engine with fuel or will the ecu correct it?
Dc4LsTeG's Avatar
EK9
Default Re: Tune question regarding injectors
Yes
Old May 16, 2012 | 10:20 AM
Fnix's Avatar
so i'm better off running the old turbo basemap for now so my injectors will be adjusted at least?
Old May 16, 2012 | 10:23 AM
Dc4LsTeG's Avatar
EK9
So you said you had the set up tuned then just put everything else in another car why would you use that? Why would you try to use a stock map?
Old May 16, 2012 | 10:24 AM
scmil95eg's Avatar
The fuel map/table is what tells the ECU how long to hold an injector open depending on load and rpm. If the stock fuel map is calling for 3 ms of pulse width at 4500 rpm and 50 kpa, it's going to hold your injector open for 3ms - regardless if your injector flows 200cc/min or 2200cc/min.
The ECU has no idea what size injectors it's controlling, it's simply holding a circuit open for a predetermined amount of time.
A stock ECU can not compensate for different sized injectors. Your engine will run very rich if you can't 1) run the stock injectors or 2) modify the fuel map.
Old May 16, 2012 | 10:25 AM
Fnix's Avatar
same car, just took out the turbo and put a stock basemap on it but left the injectors and resistor box.
Old May 16, 2012 | 10:26 AM
Dc4LsTeG's Avatar
EK9
So its not turbo anymore? Take out those injectors and put the stock ones back with the stock map
Old May 16, 2012 | 11:04 AM
Fnix's Avatar
so the ecu wont adjust the flow?
Old May 16, 2012 | 11:07 AM
Dc4LsTeG's Avatar
EK9
No
Old May 16, 2012 | 12:09 PM
dpetro1's Avatar
he can run a stock map scaled for the 450's, it should run fine. stock ecu and injectors would be best though
Old May 17, 2012 | 06:48 AM
90da_teggy's Avatar
I would think you could leave the turbo tune in. no turbo, no boost
Old May 17, 2012 | 10:06 AM
wmac's Avatar
this
it won't go into the positive pressure part of the maps.
Old May 17, 2012 | 03:04 PM
90da_teggy's Avatar
Exactly, might be a little off cause it can breath now. My maps are a little rich near the transition to boost other then that it should be fine.
dritan
Mar 20, 2011 01:18 PM
drzfamas718
Jan 12, 2010 12:17 PM
91crx93civic
Engine Management and Tuning
Mar 22, 2009 07:51 AM
egturbo
Jul 14, 2003 12:21 AM
Lyonel
Nov 13, 2001 09:50 AM
