b18c1 del sol runs rough when warm
Old May 15, 2012 | 09:24 PM
n20delslow's Avatar
Default b18c1 del sol runs rough when warm
after driving a few miles and shut it down then try and start it 10-30min later it runs rough sounds like a subi instead of a honda and runs fine after it sits for a hr or 2 and im not sure where to start,checked plugs and wires and they looked fine
mods are msd sci-l box blaster 2 coil msd cap no name header and short ram zex nitrous kit apexi vafc
quick vid of it running rough http://youtu.be/sJd6dpO-dnM
Old May 16, 2012 | 10:23 AM
n20delslow's Avatar
Default Re: b18c1 del sol runs rough when warm
another quick vid
http://www.youtube.com/watch?v=Fh7XnLPwilg
Old May 18, 2012 | 01:55 AM
StrokeDC2's Avatar
bump cuz im having the same problems in my DC. Sounds like a subie and feels like it has a lag driving till after vtec engages, runs good and strong. : ( I would like to know some inputs on this myself.
Old May 18, 2012 | 09:17 AM
civickiller's Avatar
pull a spark plug wire one at a time and see which one doesnt cause the idle to change.
pull the spark plug, is it wet with fuel?
switch 2 cylinder plug wires to rule out plug wires
pull cap and inspect
do you have a compression and a leak down tester?
Old May 18, 2012 | 05:33 PM
fcm's Avatar
fcm
Old Fart
As mentioned pull the plug leads and see if one of them does not change anything, also pull the plugs and see if your running rich, if so, check the ECT sensor. 94
Old Jun 20, 2012 | 05:23 PM
n20delslow's Avatar
after replacing all ignition components it ended up being a bad fuel injector
Tyler Lemke
Jan 1, 2016 08:03 AM
rsanders21
Oct 25, 2010 05:19 PM
J's91Teg
Jan 13, 2010 04:43 PM
ASpec818
11
Jan 2, 2005 05:29 PM
ijjz
11
Aug 24, 2002 06:02 PM
