msd plug wires keep popping off!
the 2nd and 4th spark plug wires (from the left) keep on popping out after 10 minutes of normal driving. what should i do to prevent this? are there any physical damages to your engine ora nything when running on a car without 2 spark plugs? I noticed i drove for a while liie this but everytime i check under the hood, 2 spark plug wires are off.
Re: msd plug wires keep popping off! (ASpec818)
Yo I`m having the same prob, i have a 93 hb with a gsr swap. i have an MSD cap and coil and my wires always pop of off the distrubuter a little cause my car to jump and jerk at WOT anyone got any ideas????
Re: msd plug wires keep popping off! (BigT)
i think he meant that the wires are popping off his spark plug. i'd make sure there's anti-seize on the threads of the spark plug and that the plugs are torqued down properly. a loose spark plug might cause the plug wires to pop off.
GDD Member
Flame me, call me a hater, or reduce my rating if you want, but this is the stupidest thread I've ever read. Come on guys, is this issue so hard to deal with that you need the internet to help you?
1. If it falls off the plug, remove wire, push red wire portion through the grey boot until the brass comes out, then with a pair of dikes(cable cutters), modify the brass piece so that it's smaller and will grip the plug tip better, then pull the wire back through the boot and install.
2. If wire keeps falling off the cap -
A. See step 1
B. Zip tie method as previously mentioned.
A. See step 1
Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">Flame me, call me a hater, or reduce my rating if you want, but this is the stupidest thread I've ever read. Come on guys, is this issue so hard to deal with that you need the internet to help you?
A. See step 1
B. Zip tie method as previously mentioned.</TD></TR></TABLE>
NO NO NO!!! its coming off of the Dizzy. and it happens all the time
A. See step 1
be professional
Re: (BigT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigT »</TD></TR><TR><TD CLASS="quote">
NO NO NO!!! its coming off of the Dizzy. and it happens all the time</TD></TR></TABLE>
Are you really that brain-dead?
Re: (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">theres a metal piece in the boot. squeze them a bit and then try plugging them back in.</TD></TR></TABLE>
