help please boost problem
okay well i have a full built b16 with a percision 6262 turbo one month old and everytime i hit boost my car only going to 5psi (8psi spring) then at 45-6k rpm it will cut off and go back to vacum 20
car has
3 bar gm map
880 injectors
walbro 255
tail waste gate that works tried diffrent wast gastes
greedy type rs bov
custom intercooler
custom manifold
68mm throtle body
skunk 2 intake mani
and
built block built head
please help out
stumped on this changed spark plugs changed out map waste gates and some other things
car has
3 bar gm map
880 injectors
walbro 255
greedy type rs bov
custom intercooler
custom manifold
68mm throtle body
skunk 2 intake mani
and
please help out
I was having a problem like this, But my car has a boost cut at 15psi & it was cutting at about 10psi. Ended up having a hole in the line going to the boost gauge and boost was actually higher then it was reading. So I replaced the line and turned down the boost. Now it runs fine.
no boost leaks
going to get it hooked up on the live feed to find out about the tps and i have changed maps but ill try a stock map tomorrow
thanks for the feed back
