set timing after head removal
Old May 11, 2012 | 11:45 AM
lazyxmofo's Avatar
Default set timing after head removal
so i got a new head for my d16z6 block and im kind of confused on setting the timing. before i put the head on, do i spin the camshaft till the "UP" is at the top which is TDC? then do i spin the pulley till the #1 piston is at TDC, then put the head back on? am i getting the right concept here or am i off??
Old May 11, 2012 | 11:52 AM
98civdx's Avatar
Master Detailer
Default Re: set timing after head removal
The cam gears UP mark should be point up, that is TDC.
The crank pulley "tick" mark should be pointing towards the < mark on the timing covers.
Should like this. < -
<= timing cover.
- = mark on crank pulley.
Old May 11, 2012 | 12:30 PM
lazyxmofo's Avatar
so basically i spin the pulley until the dash mark is in between the "<" mark and its suppose to look like this "< -"? in the picture thats it right?
Old May 11, 2012 | 12:36 PM
98civdx's Avatar
Master Detailer
Pretty much, yes. Make sure you are spinning counter clockwise.
I find it easier to set the timing first, and then just check it once it's back togther.
Old May 11, 2012 | 01:23 PM
lazyxmofo's Avatar
how come i have to spin counter clockwise? here are a couple pics.
Old May 11, 2012 | 01:26 PM
Former User's Avatar
The cam and crank won't stay in time if you turn the crank clockwise (engine turns counterclockwise when running).
Old May 11, 2012 | 01:33 PM
98civdx's Avatar
Master Detailer
^That.
Yep, thats what it should look like.
Although, me being very **** when it comes to these things, i like it a little closer.
Old May 11, 2012 | 01:54 PM
lazyxmofo's Avatar
alright thanks...I'm going to re do it after i clean the pistons a little...hopefully it starts ok.
Old May 11, 2012 | 02:11 PM
05foresterxt's Avatar
use the manual and read step by step and you should be fine.
TekBuDDy
Sep 21, 2018 03:28 AM
haas480
Mar 7, 2010 08:06 AM
musikpal
Aug 28, 2009 08:38 AM
civbeater90
Nov 16, 2002 12:46 PM
89JDMcrx
Sep 25, 2002 05:22 PM
