98 Civic radiator fan not working
I have a 98' cjvjc, the cooling fan was not coming on I hooked it up to 12volt source and it came on. I replaced the relay and it worked once and will not come on again. Suggestion?
after replacing the relay the fan went on once. i turned the car off restarted it again, let it idle and the fan would not come on when the engine started to get hot
Is coolant low in the radiator or reservoir?
Have you bled the cooling system?
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
wildbill_52280
13
Jun 26, 2017 04:37 AM
spidermancivic
May 5, 2009 09:07 PM
