Throttle plate closed, how does engine get air?
Old May 10, 2012 | 11:43 AM
Fnix's Avatar
Default Throttle plate closed, how does engine get air?
Just wondering, when a car is idle the throttle plate is closed, so how is air getting into the engine? My intake manifold doesnt have a IACV either.
Old May 10, 2012 | 12:04 PM
hondamark35's Avatar
Default Re: Throttle plate closed, how does engine get air?
No IACV? which engine?
Old May 10, 2012 | 12:31 PM
scmil95eg's Avatar
My intake doesn't have IAC either - the throttle body does. The IAC motor controls the amount of bypassed (idle) air.
If there's no IAC, I would suspect you have a DBW car, in which case the ECU sets the throttle angle for target idle speed (no IAC)
If it's not DBW and there is no IAC, there must be a mechanical adjustment screw or throttle stop of some type (like a carburetor)
Engines don't run without air so it has to be getting in there somehow.
Old May 10, 2012 | 02:07 PM
sc34dc4's Avatar
You should have an idle air adjustment screw on your TB.
Old May 11, 2012 | 07:03 AM
Fnix's Avatar
I do, but how do i know where it needs to be?
Old May 11, 2012 | 09:39 AM
sc34dc4's Avatar
Your car should idle around 750 when completely warmed up.
EVS90
Mar 16, 2014 04:27 PM
Fnix
Jul 7, 2012 06:45 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
k_lude
Oct 2, 2006 07:25 PM
Shft@9GSR
Apr 15, 2002 11:47 AM
