help. del sol rear garnish removal.
Old May 9, 2012 | 06:45 PM
mish__'s Avatar
Default help. del sol rear garnish removal.
Sweating my butt off in the garage trying to take my del sol's rear garnish off. Anyone know how to get it off? I hear vice grips and cut off tool, but I want to be sure and which parts. So far I see, 3 in the middle, 2 on top and 2 on the bottom. Thanks.
Old May 9, 2012 | 07:11 PM
78F350's Avatar
Default Re: help. del sol rear garnish removal.
Are you talking about this?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-do-you-remove-rear-plate-garnish-del-sol-2619827/
I think its 2 top, 2 bottom, and *2* middle. I just used vice grips on mine (2 middle) and a deep socket 12mm I think on the top and bottom. The middle ones are basically 2 rounded nuts inside the trunk. Grip it by the nuts and turn. ( sounds kind of painful actually)
Old May 9, 2012 | 08:18 PM
mish__'s Avatar
https://honda-tech.com/forums/showthread.php?t=2619827
Yeah, that.
So if I use vise grips, I can twist from the outside...
and if I use dremel, I can cut from the inside?
Hm... I thought there were 3... 1 in the middle? If not, Idk what I unbolted, but they're the 10mm right? So grip it while the nut is on it or take it off? Yeah, its beginning to sound dirty.
Old May 9, 2012 | 08:43 PM
78F350's Avatar
I don't think those studs will turn easily. The round nuts inside the trunk were easy to take off with the vice grips.
Remove the 2 upper and 2 lower (10mm) nuts. Remove the 2 middle nuts with vice grips or cut with a dremel. Then you should be able to remove the garnish/panel by just pulling it off.
Yes.
Probably 10mm. I was just guessing at the 12mm. It's been a while.
ej1ryder's Avatar
U ever work a dremel b4? Its fina take some finnesse. Buts its the easiest route.
Old May 9, 2012 | 10:17 PM
mish__'s Avatar
Yes.
You're correct. 12mm 4 bolts and 10mm 3 bolts.
So twisting bolt means to twist the black screw ends after I take the nut off right?
Old May 9, 2012 | 10:20 PM
mish__'s Avatar
I just got one recently. But, a black and decker. Im happy with it. I put the jdm fillers on the edm panel. Im gonna have to dremel the body for rear fog anyways. I want to take the panel off as clean as possible. But, if I would have to dremel, just cut both screws from the inside off? Im gonna have to take some pictures of the panel x__x
Old May 9, 2012 | 10:26 PM
Dpsych's Avatar
i used a dremel. only way i could get them off
Old May 10, 2012 | 12:07 AM
ej1ryder's Avatar
just take your time and dont make any quick movements, the black and decker isnt bad at all. just keep your hand steady and make sure u use some goggles or safety glasses, u dont want metal flakes in ur eye. post some pics wen its done.
EssEg
19
Mar 19, 2011 08:20 PM
EssEg
Paint and Body
13
Mar 18, 2011 06:26 AM
aftershock2686
Mar 23, 2008 09:20 AM
