b18b Eg just died; now ACG fuse keeps blowing
Old May 8, 2012 | 07:53 AM
Dank_dc2's Avatar
Default b18b Eg just died; now ACG fuse keeps blowing
I have a 1992 civic hatchback cx which i just put a b18b in roughly a month ago. The swap was purchased from HMO.
I was driving down the road and it just cut out like you turned the key to off.
when i started it before i took off it was idling real low around 200 or 300 rpms
i headed off down the road and there was no problems at all.
and it just all of sudden died.
There is no spark from the dizzy.
I tried using my buddys dizzy of his usdm ls and it didnt work
I haven't been able to figure anything out.
There is also a loud humming noise coming from the wires running up to my driver sides lights
Before this the car ran 110%
any ideas?
Old May 8, 2012 | 08:10 AM
d15bvtechatch's Avatar
Default Re: b18b Eg just died
so both dizzy's have no spark?check fuses
Old May 8, 2012 | 08:13 AM
Dank_dc2's Avatar
i checked all the fuses and relays
Old May 8, 2012 | 08:20 AM
Allurian's Avatar
check your ignition system. The problem is most likely an electrical one
Old May 8, 2012 | 08:26 AM
Dank_dc2's Avatar
how do I check it? and what am i looking for exactly?
Thanks and sorry im not really good with electrical lol
Old May 8, 2012 | 10:09 AM
EGyoke's Avatar
Does it crank when you turn or no? Check the timing belt too, but if no crank or signal then you def. have a lose wire or ground that shorted something out. Ignition problems prior? Car stolen before?
Old May 8, 2012 | 10:23 AM
Dank_dc2's Avatar
it turns overs and timing is fine, not that i had at all, and most likely with all the stuff i keep finding with this car
Old May 8, 2012 | 11:04 AM
beecee18's Avatar
relay
ig switch
ecu grounds
Old May 8, 2012 | 03:52 PM
Dank_dc2's Avatar
relay is fine
where are all the grounds
how do i check the ig switch?
Old May 8, 2012 | 06:27 PM
beecee18's Avatar
http://techauto.awardspace.com/ignitionswitch.html
this guide can be used to troubleshoot and or replace your ignition switch, go straight to the instructions on how to jump it to rule it out.
G101 is where all the important ecu grounds congregate, it is located on the thermostadt housing towards the rear of the engine on the passenger side.
wire brush the conector and the mating boss and re-install.
GL duder!
Old May 9, 2012 | 08:10 AM
Dank_dc2's Avatar
It isn't the ig switch
I'll clean up the connectors and let you know if it makes a difference
Old May 9, 2012 | 11:43 AM
Dank_dc2's Avatar
i cleaned it up and it still doesn't start
Old May 10, 2012 | 04:18 AM
EGLS631's Avatar
sounds like the same problem my buddy had... his car would shut off when he was driving.. he figured it was the ignition switch, changed that.. wasnt the problem.. he checked all his fuses and relays.. couldnt find anything wrong, they all checked fine... ended up being the Main relay.. he replaced that and hasnt had a problem since.
Old May 10, 2012 | 05:05 PM
Dank_dc2's Avatar
there was a wire disconnected on my ecu harness, they've all been hacked into
we got it running but now it completely melted the ACG fuse, i replaced it and it burnt it out right away
Old May 10, 2012 | 05:42 PM
spoofmastafly's Avatar
You have a short somewhere now. Trace your wires that are coming out of the fuse box.
Old May 10, 2012 | 06:14 PM
Former User's Avatar
Check all alternator wires (4P connector wires and large white that runs to the hood fuse box).
Old May 14, 2012 | 07:44 AM
Dank_dc2's Avatar
Default Re: b18b Eg just died; now ACG fuse keeps blowing
after looking around for awhile, the entire dash harness is all hacked and effed up
my main relay got incredibly hot and and the wires actually melted in is hand
im just going to replace the entire harness
Old May 14, 2012 | 07:45 AM
Dank_dc2's Avatar
Thanks for all the help guys!
Old Apr 11, 2013 | 09:03 AM
Honda gurl 76's Avatar
hello I seen threads all over with no answers when I had this issue bout month ago 3/18/13!! Okay so my acg fuse would blow as soon as I turn on , no start! I changed many things ecu, ignition cap rotor module, coil pak spark plug battery checked altenator, radio under hood/dash fuses... It is a short!!! That can make anyone loose there mind I even changed the fuel pump!!!! >>>> here's the RESULT N SOULTION N WAT WASSSSSS MY PROBLEM, my brother who was busy at the time finally looked at it, n he changed the fuel pump again NOT JUST THE PUMP LIKE I DID, the whole entire thing : turns out.... The was a short in the actual fuel pump ( no good) he changed it, looked me in the eyes as if ( I'm the snit) n bammm 3 weeks later my car as been running n no more acg fuse dying it took me ( a car clueless girl) 2 months to figure it out tears, frustration mental anger lol honda baby! N these acg fuses threads are all shitty n made me spend money here the pump cost me $40 after all I spent n did : hope it helps many ppl just change the entire fuel pump not just the pump pill!!! GOOOD luck my car 93 eg coupe 1.6
da9253jdm
Aug 7, 2013 03:15 PM
v8killaz
12
Jun 20, 2011 10:28 PM
delslow302
Apr 12, 2009 03:04 PM
mrlegoman
Dec 10, 2008 01:29 PM
Sephro
Feb 20, 2004 06:18 AM
