How can I get my cam timing top dead center?
Old May 7, 2012 | 01:23 PM
Azimmer's Avatar
Default How can I get my cam timing top dead center?
I messed up the cam timing when trying to put my belt back on so what is the best and easiest way to get the cam and crank timing top dead center so my timing isn't jacked anymore
Old May 7, 2012 | 01:36 PM
chewyv's Avatar
pm4nudes
Default Re: How can I get my cam timing top dead center?
You can't. Once it's off then it's off. You're pretty much screwed...
Old May 7, 2012 | 01:45 PM
Azimmer's Avatar
There has to be a way, I've heard of it done before
Old May 7, 2012 | 01:51 PM
Dc4LsTeG's Avatar
EK9
Op take the belt off and redo it
Old May 7, 2012 | 01:52 PM
chewyv's Avatar
pm4nudes
Are you doubting my intelligence?! Preposterous! Inconceivable!
Old May 7, 2012 | 01:56 PM
grumblemarc's Avatar
The Grumpiest
Follow this advice. I don't know WHAT the other guy is on.
Old May 7, 2012 | 01:58 PM
chewyv's Avatar
pm4nudes
I thought you were away and gdd got boring.
Old May 7, 2012 | 02:00 PM
chewyv's Avatar
pm4nudes
I would've helped him, eventually.
Old May 7, 2012 | 02:03 PM
Dc4LsTeG's Avatar
EK9
GDD
Explains everything
Old May 7, 2012 | 02:04 PM
civicjunkie17's Avatar
http://www.youtube.com/watch?v=Uy_uR-UoUVQ
Watch from :30 until 2:30
Old May 7, 2012 | 02:55 PM
98civdx's Avatar
Master Detailer
Set cam timing to TDC, remove the belt and set the crank to TDC, put belt back on. Rotate several times and check the timing again to make sure you aren't 1 tooth off.
Old May 7, 2012 | 03:03 PM
Azimmer's Avatar
I can't even get to the damn belt tensioner lol I spun the cam by accident and attempted to put it back so I don't even know how to get my crank to top dead center.
Old May 7, 2012 | 03:04 PM
Azimmer's Avatar
FYI my motor is a
Stock d16y7 single cam
Old May 7, 2012 | 03:07 PM
The Grumpiest
Jeez. FAQs. Look through them. There is a link on how to set timing on a single cam.
Old May 7, 2012 | 03:10 PM
Azimmer's Avatar
Thanks kitty Kat haha
BoostedH
Dec 9, 2008 10:34 PM
B16B_coupe
Dec 16, 2006 09:42 AM
Civicman86
Jun 24, 2006 07:12 AM
ludewithanh22
Oct 1, 2004 09:20 AM
civickiller
Mar 8, 2004 11:34 AM
