Can't tune real time with Crome Pro
Hi everyone,
I'm having the most annoying problem here. I can't tune my car in Real Time with Crome. I have confirmed that it is something with my car because I have swapped the ecu's that I tested in my car into another car and they all tune Real Time just fine. When I try to connect to the Real Time port I get an error code (a weird one that I haven't seen before and also cannot remember) and then Crome freezes. This only started happening this year. Have any of you had this problem before?
Car is an EF with a gsr swap. I did the wiring myself about four years ago and everything (including live tuning) has worked fine until about a week ago. There are no obvious wiring issues (not ruling a wiring problem out though). Thanks!
Export maps and all setting into a new bin. Pro so you should not have to add rtp if your using a gold bin. The new version has some more setting in the rtp section.
Did you just update your crome?
I did just update Crome. I could not operate the program without doing so. I have also reinstalled the old version. Neither version works.
Can you please explain what you mean in the first line of your post?
Ok um make a new bin and see what happens using your old maps. You can do this by exporting tables.
Check to make sure all your setting are correct in the real time menu.
CRJenkins13
Audio / Security / Video
Aug 8, 2009 08:28 AM
Kavehman
Nov 4, 2004 05:47 PM
quik1
Dec 7, 2003 10:26 AM
