92 civic cx/B16 swap - Will a PR4 ecu work?
I have a b16 in my 92 civic and my old ecu (p30) died so i ordered a ecu off ebay and i ask for a p30 and to lower vtec so the new ecu comes and its a pr4 so i try to use it and vtec will not turn on and the iacv i unplugged cause it the idle wonders up and down all the time now, so will this ecu even work i looked up the pinouts and on the pr4 theirs no knock sensor so how will vtec even work then.? any ideas witch wires i might have to switch?
maybe you got ripped off if you were supposed to recieve a p30 that you asked for????
Creating a thread title that summarizes your specific tech problem helps you get more responses by letting members know what specific information is needed -- Title edited.
PR4 is a non Vtec LS ECU. The OBD1 version can be chipped and converted to a vtec ECU, but I have no idea without seeing pictures of the ECU board if yours was or not.
PR4 wont look for a knock sensor btw.
ok so the switch inside the ecu was off for the chip i turned it on and the car runs normal except for VTEC WILL NOT ENGUAGE so this clown says that you dont need knock sensor for vtec, is that true? i have to wire in a knock sensor for my old p30.
I still don't know if the board was converted to vtec though without seeing pics. Just chipping it and burning a P30 Eprom on a chip wont work, vtec still wont engage until you solder physical components to the board.
Btw, what happened to the P30? Big capacitor blow up? You can usually fix them.
on the old p30 the fuel pump just stopped working with that ecu so i got this new one and every thing works fine except for vtec working and i looked for a p30 and p28 for the last month and no one has any so i decided to buy this one off of ebay
Other than getting the right ECU it doesn't matter, once they're chipped it doesn't matter what the ECU was originally for. PR4, PR3, P28, P30, P61, P72, P05, P06 once you chip them and add vtec components to the board on the non-vtec ones they all work the same.
unless you just get your rocks off on doing vtec conversions on boxes for fun.when everybody and there mom owns a $#!T-Ton of these things like trading cards. just doesnt make sense plug and play right when you recieve it in the mail. or have to trust some goon soldering up your non-og to your setup odd-box with no knock sensor???????
This is the link to the ebay ecu that i got it shows the conversion thats the guy did
http://www.ebay.com/itm/ws/eBayISAPI...vip=true&rt=nc
he emailed me and ask how did i know vtec wasnt hitting, so i told him ive onlly had this car fo 5 years and when the old ecu is in you can hear and feel it. so he said he checked the chip and every thing was fine, then he told me that cause i got vtec lowered to 4500 rpm that i wouldnt feel it enguage,??? i know if vtec is to low you can have problems but cmon not at 4500 rpm i dont think but i got him to set vtec at 5k now so when i get it back well see if it works
soulreaper
Apr 27, 2011 11:10 AM
civichopeful
Mar 27, 2003 03:38 PM
