p2t4 transmission not shifting in most gears
Old May 6, 2012 | 07:11 AM
blueeh2's Avatar
Default p2t4 transmission not shifting in most gears
Im trying to figure this transmission out. Its a p2t4 manual transmission that i pulled for noise. Started taking it apart and ordered all my parts. Found out that the differential was making alot of noise and the bearings were also. I also noticed that one of my syncro springs was broken so i ordered all new springs, seals, bearings and decided to upgrade to an MFactory lsd. almost had it back together and noticed that i broke my bellhousing.....F$%%, but i stayed calm. I found a bellhousing from a 92 accord that looked almost like my original because it didnt have the little notch on the top beside the starter, it was smooth like my p16. cleaned it put it together and installed it and it would only shift into some gears like 1 3 5 ......pulled again took apart cleaned put together filled started car to see if it made a difference...still not shifting correctly. Pulled again cleaned inspected bought the helms shop manual put back together didnt fill this time but now it will only shift into third and reverse. This is my first transmission rebuild and i dont know what else to do.
Anyone that has experienced these problems or anyone with any ideas please throw something at me.
Old May 11, 2012 | 06:19 PM
blueeh2's Avatar
Default Re: p2t4 transmission not shifting in most gears
Should I just take it apart again
BrandonNye33
Transmission & Drivetrain
Jun 28, 2019 10:49 AM
Uncle Seth
Feb 12, 2018 12:44 AM
fryman
Sep 16, 2008 10:10 AM
drvfast
Jan 1, 2004 07:25 PM
euclidEH3
Aug 8, 2001 10:44 AM
