Input Shaft Bearing?
Old Jan 1, 2004 | 03:36 PM
drvfast's Avatar
Default Input Shaft Bearing?
What happens when this bearing goes bad. I know it makes a whining noise but can anything happen, to other parts in the tranny? Thanks
Old Jan 1, 2004 | 04:46 PM
acy76's Avatar
Default Re: Input Shaft Bearing? (airshifta)
I just opened up a 92 YS1 with a bad input bearing. A couple of the ball retainers had broken off and were attached to the magnet, as well as lots of metal shavings. From looking at it, it would be hard for the ***** themselves to get out of the race and into the gears, but if left long enough, I guess anything is possible.
Also, the 3-4 shift fork was work in a strange way - one of the prongs was worn down noticeably where it touches the synchro sleeve, while the other side was in perfect shape. Since the worn bearing seems to allow for some movement of the mainshaft, my guess is that this could have caused the odd wear pattern.
Your best bet is to fix it.
EDIT: forgot to add that the gears looked fine. The missing retainers were all accounted for on the magnet, and they are not made of very hard metal. If something tougher goes through the gears, you could be in trouble.
Old Jan 1, 2004 | 07:25 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifta &raquo;</TD></TR><TR><TD CLASS="quote"> but can anything happen, to other parts in the tranny? Thanks</TD></TR></TABLE>
not fixing this will kill the rest of the tranny
95_Civic_4dr
Transmission & Drivetrain
Jan 25, 2011 10:26 PM
88 rex
Apr 2, 2006 07:23 AM
DB1_559
Jan 28, 2006 05:58 AM
vg7z
14
Jul 23, 2005 06:33 AM
user 98292739
Feb 21, 2005 02:27 PM
