manifolds?
Old May 3, 2012 | 12:10 PM
b18c99si's Avatar
Default manifolds?
i have an itr bottom end with a gsr head. wht would be the best manifold to put on there or should i change back to a b16 head and go from there?
Old May 3, 2012 | 01:24 PM
racebum's Avatar
Default Re: manifolds?
heads are virtually the same. value wise you should use the pr3 head. realistically you should use which ever head is in better condition. manifold on the cheap for the gsr head = blox. manifold for best 9000 and under = performer x. on the pr3 head, you can use a p73, blox, performer, take your pick, basically the same thing other than the p73 manifold being able to fit
Old May 4, 2012 | 04:22 AM
b18c99si's Avatar
Thanks I'll look in to it.
92b16si
Dec 11, 2006 04:52 PM
Mistermark
Apr 28, 2006 12:12 PM
the4ork
Dec 12, 2005 06:16 AM
highrevnef
Apr 14, 2005 05:59 AM
Twenty36_1
Aug 5, 2004 10:56 PM
