h23a1 crank pully
Will a fluidampr crank pulley for a h22 fit a h23? I don't see a good aftermarket crank pulley for my h23a1 93 Honda prelude. If it won't fit is there any company's out there that make one that fits my particular engine?
Not sure about 4th gen h22 crank pulley but neither of my h23 crank pulleys fit my friends 97 sh prelude (h22a4). Havent tried it on my 98 base though, it may be different I never cross referenced the part numbers. They will physically bolt to the crank because I was using one on my 98 spec h22a4 on the stand.
Well, just remembered I have a f23 crank in the block on the stand. Dont know how that changes things. Ill look and see if I have an h22a4 pulley boxed up somewhere and see if it fits on my h23. I Dont have a head for it so judging correct belt spacing wont be feasible.
OK thanks for the help! I'm gonna order a fluidamper crank pulley for a h22 and feel fairly confidante it will fit on my h23a1. Just hoping that there is no belt alignment issues. Should be no prob if snobordoia was doing it with no problems. Any more info would be great on what will interchange with what motors.
i really want to order this ati damper pulley for the h22, even though i have a h23 engine. i still am not positive the h22 pulley will fit. Does anyone have a h23 and know for a fact that a h22 crank pulley will fit and belts align? i am really in a jam, i need to upgrade this pulley asap but im not sure if there is a good replacement out there.... HELP...... ive contacted ati and they say that since its not confirmed to fit they would have to custom make one that is $890, ill spend $400 but i have better things to sink the extra $500 bucks into, I refuse to spend $900 on a pulley when the h22 might bolt right up..... like i said im in a JAM....
Ok let me put it this way, I have 2 different engines I swap back and forth in my car.
One is a JDM H22A, bone stock.
One is a H23 I built, using an H23A1 crankshaft.
I have one stock crank pulley that I swap between both engines, depending on which one I am running at the time.
Ok im going to order a jdm h22 damper then. I believe this info to be true. What is the last letter and number of the h22 jdm engine. H22?? Thanks im goin to look for this model engine and order. Just wanta make sure i got the jdm engine correct. Thanks!
