only able to tune WOT????
So I was talking to my tuner the other day about my simple b16 turbo setup. I'm running open downpipe that ends right about at the middle of the flywheel cover. The o2 sensor hold is about 7 inches away from the turbo. He said he won't be able to tune idle or partial throttle. Is this true? Should I extend my exhaust a little bit?
They're a legit tuning shop though. Good reviews and whatnot. He said the o2 sensor would see too much fresh air? Sounded weird to me, but I'm not a tuner
OK so you mentioned that the O2 was 7" from the turbo. How far is it from the end of the exhaust?
If you feel that they are legit then why question them? You should do what they recommend you to do....
12" may be a bit short, however, what did your tuner tell you would be the minimum length he could tune with? I guess that would be your best bet to keep him happy. and a happy tuner makes for a happy customer.
There are tuners ou there that use the tail pipe sniffers to tune.
To be honest with you, you should ask them these same questions and see what they say. Better to get to know your tuner than to get misinformation online.
We don't know what your tuner can and can't do or what they prefer.
I understand his theory behind not wanting to tune part throttle/idle w/ such a short exhaust, but its still not that hard to read... I have no problems getting accurate AFR's on my open DP. My WBO2 is only 6" away from the end of the pipe.
my wbo2 is in the stock location which is a good 12-14" away from the turbo and im able to tune idle and part throttle very well..
your tuning is giving you wrong information or you miss understood him.....OR he just sucks.
IMO if he's not comfortable tuning the way it is, why not just find out how much of a tail section he would like put on? Can't cost jack and it will put him in his comfort zone.
Vryantec
Engine Management and Tuning
18
Jul 31, 2018 03:35 AM
the.hamburglar
Jun 12, 2005 03:47 PM
92HB_HB
May 11, 2005 06:06 AM
