P0171need info
Old Apr 30, 2012 | 07:57 AM
shino83's Avatar
Icon2 P0171need info
Hey I have a 2006 Civic SI and the check engine light came on which it running lean(P0171)...What can I do to fix this issue?
Old Apr 30, 2012 | 08:38 AM
crzdmngz's Avatar
Default Re: P0171need info
Click Here
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor.
Possible Solutions
Possible solutions include:
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
Old Apr 30, 2012 | 11:40 AM
fcm's Avatar
fcm
Old Fart
Cleaning the MAF sensor yes, with brake cleaner no, get the correct product...
http://www.canadiantire.ca/AST/brows....jsp?locale=en
just about any car parts shop will have it. 94
Old Apr 30, 2012 | 01:39 PM
turbohatch96y7's Avatar
Damn fcm I just noticed you had 20000 post..
On another note I didn't know the new si had a maf sensor
Old Apr 30, 2012 | 04:23 PM
shino83's Avatar
thanks.....
Dennin01
Acura TL, RL & ZDX
Sep 23, 2018 07:17 AM
holmesnmanny
Honda Civic (2006 - 2015)
Mar 16, 2017 12:41 AM
shino83
May 3, 2012 08:37 AM
r.etheridge
Feb 13, 2011 02:59 AM
99d-series
May 1, 2009 08:56 AM
