P0171need info
Hey I have a 2006 Civic SI and the check engine light came on which it running lean(P0171)...What can I do to fix this issue?
Re: P0171need info
Click Here
A code P0171 may mean that one or more of the following has happened: The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. There could be a vacuum leak downstream of the MAF sensor. Possible Solutions Possible solutions include: In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling Inspect all vacuum and PCV hoses, replace if necessary Check for a dirty fuel filter and proper fuel pressure |
Re: P0171need info
Cleaning the MAF sensor yes, with brake cleaner no, get the correct product...
http://www.canadiantire.ca/AST/brows....jsp?locale=en just about any car parts shop will have it. 94 |
Re: P0171need info
Damn fcm I just noticed you had 20000 post..
On another note I didn't know the new si had a maf sensor |
Re: P0171need info
thanks.....
