B20ek speedo problems
take off the distributor cap/rotor, the cover underneath the rotor and check the connections to the ignition control module. tug on them and see if they slide easily in place or if they're snug.
It's easier to do this with the distributor off so just mark a line with a marker on the top adjustment where the distributor meets the block before you start taking the distributor off.
you can also take the ignition control module to autozone and they'll test it for you. Their little machine shows all green lights when everything is good, if any red light comes on something is wrong with it.
pspryu101
27
Dec 12, 2010 11:14 PM
