Flywheel removal???
Old Oct 12, 2002 | 06:08 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Flywheel removal???
I wanted to get my flywheel lightened while i still had the engine out of the car. I went to take the flywheel off and i noticed that there were like 10 bolts that needed to be taken off to get it off. They were all along the outside of the flywheel.
I think that they were all 12 point bolts....andi dont have a 12 point socket to fit it. What can i do to get it off? Is there anything that i should knowabout before i remove it...like if i do certain things i could break something? And do you have any tips to make it go by faster? Thanks...
PS: If you are looking at the distributer cap...what is the firing order of the spark plug? Like is the top left 3 and the bottome left 1 and the top right 4 and the bottom right 2?
Sean
Old Oct 12, 2002 | 07:13 PM
Aphrodavid's Avatar
Default Re: Flywheel removal??? (sCeRaXn)
first off, if youre going to be doing your own work on your car, get a helms manual. second, you NEED the special socket to take those bolts off. if you use a standard 12 point socket, you be in a world of hurt. and if im understanding you right, youre discribing the presure plate. the flywheel is held on by 6 bolts in the center of the flywheel.
Old Oct 12, 2002 | 10:00 PM
sCeRaXn's Avatar
Default Re: Flywheel removal??? (DX-R)
Yea thats what i meant...i need to get the bolts off of the pressure plate to get to the flywheel. I dont know why i didnt put that at first...thats what i get for posting right after a sat. nights activities . So i have to get a special socket? Where can i get this at? Thanka alot.
Sean
Old Oct 12, 2002 | 10:31 PM
Superhatch's Avatar
You dont need a special socket. I got a 10mm 12pt. and a 17mm 12pt from checker auto...and they worked like champs (I just did it today!!). The hardest thing is to get the pully to stop turning. Use another ratchet on the pulley end with a 17mm and something to brace it with..then just crank away. There is a torque value for those things going back on..might want to rent a tq. wrench for that.
-Jake
Old Oct 12, 2002 | 10:40 PM
Aphrodavid's Avatar
Default Re: Flywheel removal??? (SuperHatch)
impact wrench is your friend
19ft/lbs to be exact
Old Oct 13, 2002 | 08:46 AM
sCeRaXn's Avatar
I was thinking that a 10mm 12pt socket would work...but what is the 17mm for? Do i need it to take off the flywheel after i get the pressure plate off? Ive got a torque so i wont need to rent one. Thanks.
Sean
Old Oct 13, 2002 | 09:18 AM
shortyz's Avatar
the 10mm are around the outside of pressure plate and the is i think 5 17mm 12 points to remove PP.
am i right here?
Old Oct 13, 2002 | 09:33 AM
Chiovnidca's Avatar
Default Re: Flywheel removal??? (shortyz)
The 17mm 12pt. is for the flywheel bolts.
Juan_Mitosis
60
May 20, 2016 07:20 AM
JDMInspired
Honda Civic (2001 - 2005)
Mar 17, 2008 08:57 AM
92integraVTECgsr
Apr 21, 2006 05:08 PM
snatch
Aug 20, 2004 09:56 AM
3rdGteg
Sep 3, 2002 09:52 PM
