y8 head on z6 block quick ??
Old Apr 24, 2012 | 08:00 PM
z6dxej1's Avatar
Default y8 head on z6 block quick ??
i bent my z6 valve so i got a y8 head from a friend....my ? is,, is it 9 z6 studs and 1 y8 or the other way around....and also do i put the z6 cam gear on the y8 cam?
Old Apr 24, 2012 | 10:19 PM
apexi_rsx's Avatar
Default Re: y8 head on z6 block quick ??
u can swap out the valves from the y8 head they are the same. this could make this simple and ur computer would still be the same tune. A y8 head would raise compression. if u do put the y8 head on put the z6 cam gear on it and time it the same as a z6. To put the Y8 head on the Z6 block, you need 9 head studs/bolts from the Z6 and 1 from the Y8. That 1 stud goes by the vtec solenoid
The93egg
Oct 28, 2008 08:27 PM
gnar kill
11
Nov 6, 2005 09:43 PM
tai93si
Jan 16, 2004 07:36 AM
94dxt
Dec 14, 2003 07:10 AM
SOHC_MShue
Jun 1, 2003 12:30 PM
